Recent conservation work at the Pope-Leighey House, built for Loren and Charlotte Pope in 1939 and now owned by the National Trust for Historic Preservation, has focused on the house’s cypress cladding. Tidewater cypress was a favorite material of Wright’s and it was specified for many of his Usonian houses. Tidewater cypress is a particularly durable species and has stood up well on these houses, which range from nearly 60 to more than 80 years of age.
In a project headed by Ashley Robbins Wilson AIA, the Graham Gund Architect of the National Trust for Historic Preservation, Pamela Kirschner / Fine Art Conservation was asked to perform a pilot treatment on the Pope-Leighey House. Pamela, a wooden artifacts conservator, in collaboration with architectural conservator Andrew Fearon of Materials Conservation along with the University of Pennsylvania, performed historic materials research, scientific analysis, field testing and pilot treatment of exterior clear coatings.
The chosen clear coating has been applied to the exterior of the Pope-Leighey House. Further evaluation and monitoring of this six-year endeavor, along with further preservative testing at Penn for insect resistance, will continue in 2017.
At the Pope-Leighey House, Amteco TWP 1530 was used to protect the exterior surface of the house’s cypress cladding. Amteco TWP 1530 “Natural Tone” has pigments in it that provide UV protection. As is typical of Amteco applications, when the coating was first applied it looked a bit red. After the evaporation of its solvents its appearance changed to a honey color. The surface was prepared per the TWP specifications.
Kirschner suggests that surfaces similar to Pope-Leighey’s exterior may be prepared using D/2. D/2 removes biological material (mold or algae) and cleans off some of the previous coatings. A layer of Tim-bor to prevent mold growth can be applied before the Amteco TWP 1530.
These products are all applied using soft brushes. Sanding is not required. This allows preservation of the original wood. Following the manufacturer’s directions for each product is always recommended as well as consultation with a professional to create a work plan along with specifications. This type of project should be planned during moderate temperature when no rain is expected.
Both Pamela Kirschner and Andrew Fearon are available for consultation.
Pamela Kirschner
5315 Connecticut Avenue, NW 410
Washington, DC 20015
Email Pamela
Andrew Fearon
Materials Conservation CO, LLC
1625 North Howard Street
Philadelphia, PA 19122
Email Andrew
Pamela G. Kirschner is a wooden artifacts conservator with a private practice. She received a master of science degree in art conservation from the University of Delaware/Winterthur Museum’s Art Conservation Program in 1998. She specializes in the preservation and conservation of furniture and wooden artifacts from the 20th century and has researched and treated Wright’s Usonian exterior wood and Frank Lloyd Wright furnishings extensively as a Kress Fellow and through funding from the National Trust for Historic Preservation, Heritage Preservation, the National Endowment for the Humanities and the National Endowment for the Arts. She is a former Frank Lloyd Wright Building Conservancy board member and currently serves as a consultant on the architectural advisory committee.
2023 Update
On June, 6, 2023, Pamela Kirschner, along with Building Conservancy Preservations Programs Manager John Waters, visited the Pope-Leighey to monitor the condition of the conservation finish, six years after initial work described above. They met with Amanda Roper, Senior Manager of Public Programs & Interpretation, Woodlawn & Pope-Leighey House. The three shared their respective knowledge about the site’s history and preservation.
The protocol for wood finishing used in 2017 appeared to be to be holding up well. There were areas where there had been some loss of finish and a reapplication of the Amteco TWP was recommended. To do this wood can be lightly cleaned with D2, Timbor and TWP should be applied using a soft brush as described in Pamela Kirschner’s Work Plan.
Changes of color are an indication that coating should be added. When color change is noticeable it would be appropriate to consider applying more coating following the manufacturer’s recommendation. Any loss of the coating due to damage from animals or insects is another reason to add more coating.
An area with loss of finish can be found on the West elevation. In the photo below, there is still finish on the lower boards although the color has lightened considerably. The lower two boards have experienced more exposure to sun and rain than the boards above. Thr application of TWP may be limited to the lower boards only, but before any application in easily viewed areas it is advisable to find a less exposed area to try out the application process.
West elevation with thinning finish on lower two boards
This recommendation points to the advantage of the process used during the 2017 conservation: removal of the earlier finish (with an inevitable loss of wood) for subsequent applications is not required. Like a wood floor that can only be sanded and refinished so many times, the wood of Wright’s Usonian houses can be worn away with multiple finish removals. Also, re-application of TWP can be focused on a specific area as opposed to an entire wall or building. Once established, this process conserves effort as well as wood!
Posted March 3, 2017
